Recommended glue for glueing plywood to MDF?
Stewart: late to the party re your post #31 above, but my first thought, which you've perhaps already realized, is that most hardwoods are far harder than MDF - maple certainly. I think you could count on many tedious hours to achieve similar results to the baffles on the SP44 design.
Sorry Chris only just seen your comment, yes I agree too much work involved with chiselling maple. Might consider using MDF yet, is it really worth it though. I'd expect the diffraction to be better.
Like a lot of the slow curing 2 part epoxy glues, Cascamite it great for many applications, but does need vacuum bagging or cold pressing to ensure conformation of thinner materials to substrate, which I imagine would be a royal pain in the a$$ for post veneering of even a rectilinear box.
I suspect that Richie is referring to a process of pre-veneering panels for CNC V-grooving / folded mitre construction?
And just how much water resistance do we need in adhesives for construction of speaker boxes?
Thanks for the info Chris,
I see a lot of fuss about water resistance glues for loudspeakers, I think it maybe piece of mind or for cleaning purposes yet if anyone's speaker cabs become in contact with water/liquids, it would be dried straight away anyway. I don't think its important myself.
yeah, it'll take more than just an incidental spill of water on the finished surface to do sufficient damage to enclosure's structural integrity - in which circumstances there are probably larger worries to contend with
these aren't wooden boats we're talking about
I think Richie's Cascamite suggestion is great for this application, yet I think Chris uses Titebond 1 and will also be great too but I've never done it and appreciate everyone's comments on your experiences.
Right, seems like the vacuum bags are a no no for already constructed cabinets and come to think of it I have only seen one panel at a time being vacuum bagged although I've not really looked into thin veneering too much, especially on curved cabs. I chose a easier design for my first build but my friend is more confident and optimistic about the finish. The cabs are solid though much better curves than most and much more solid than a lot of B&W's and KEF's etc.
Thanks Cal, I have read that using shellac as a sealer will get a even adhesion to anything thats bonded to it (good for end grains etc), yet been advised on another thread on here thats not the case, I go with the latter usually but your point seams to me a good idea when painting not veneering. Off topic Cal but been meaning to ask you for a while...I seen on one of your old threads you used to use MDF/Cement board for cabinet walls yet now use BB, I like the idea of 18mm BB/6mm Cement board for my subwoofer project and would appreciate your thoughts.
Tinitus I believe you can paint on spirit dissolved shellac but the mix of spirit is increased, not sure by how much.
Cement board makes sense for mass damping - particularly if mounted with elastomeric adhesives for constrained layer, but well fit BB plywood or solid hardwood members would likely provide superior bracing / structural integrity.
Then of course, to my chiropractor's kids' disappointment (someone else can subsidize their DisneyWorld spring break), I'm very much of the "as light and stiff as the design allows " school of enclosure fabrication, and the whole brute force mass approach is not so appealing to me.
you got lots of funny stuff 'over there' 😀
not long ago I bought some special glue for mounting panels
looks like thick brown contact glue
quite effective
even dissolved the plastichorn I was working on
but man, the smell lasted several weeks, and was sick every day just being around it
Thanks Cal,
I've got the best 18mm BB I have seen waiting. I think the subwoofer enclosure will be well carefully braced as best I can and 4mm bitumen pads on panels cut around braces and glue with Evostik Contact adhesive with good 8mm carpet felt on all panels (bitumen without carpet felt seemed to have too much reflection on woofer cones in my Seas 20litre cabs), I have good results with this approach so maybe thinking the cement board won't be needed.
Thanks again Chris, I like your design intention with light and stiff designs but prefer the soundproof design at the moment, seems to work well with all kinds of music and films with am into. I like 12mm BB with rubber internal walls though with certain music, I think there's more life sometimes.
Tinitus is it like a hide glue you used not long ago. The smell of the contact adhesive I used was strong for weeks but I'd still use a strong solvent based than water based.
It does stink for a while, didn't think contact adhesive could damage the drivers aswell like silicone.
Just sound tested the cabs with only the baffle needing a skin (unsure yet what design). I must say I wasn't expecting this much difference. The bass is well more solid, midrange seems smoother and tweeter slightly louder than before (due to 7.2mm wider baffle and 3.6mm higher above tweeter. The whole cabs resonate much less than before, can't believe these used to vibrate all over each panels before bitumen, felt and plywood skin, now hardly anything. 😀 Looks much better now time to stain plywood and maybe laquer then black baffle.
