Recommendation for bookshelves under $150. Thanks
I need some help choosing a pair of bookshelves for under $150. It will be used with a "DAYTON AUDIO SUB-800 8" 80 WATT POWERED SUBWOOFER". It is mostly for near field listening at low wattage. Source will be computer. Will be using a home built LM3886 amp. I currently run the setup with Polk T15 but need another set of speakers.
Is Infinity Primus 143 worth it?
I think it's important to understand your priorities/expectations and if the $150 includes cabinets or not... the truth is it's a tight budget, and if final result is the end goal you're probably better off buying some 2nd hand bargains on ebay... I'm happy to be corrected, but I'd have thought minimum for a worthwhile diy effort budget would be $280+cabinets... at that value there's a lot of very good options... you could also raid the swap meet for something if you really want to DIY, you may find a bargain abandoned project
An Eminence Beta 8CX and a PRV D280Ti will give you a nice 94 dB sensitive setup that is very compact if you only need to go to 80Hz. $110 not including a XO which you can probably put together yourself in pieces and parts for another $40 for a$150 total not including wood for box.
Here are some box recommendations: http://www.parts-express.com/pedocs/more-info/290-500-eminence-beta-8cx-more-info.pdf
Or you might try the XKi 6th order bandpass Karlson aperture box:
http://www.diyaudio.com/forums/full-range/268524-xki-xs-ab-initio-karlson-6th-order-bandpass-15.html#post4208201
