hello all, finally going to try a diy project! I choose to build speakers instead of buy them from a store... no fun in that. hehe
The main use for them would be for dvds/movies so a 5.1 setup. As for music I don't listen to music much, but when I do I listen to rap mostly. Probably 90% is used for 'home theatre' and the other 10% music. Currently i have a pair of 12" Fisher STV-420M and an H/K 230.
Ive never listened to rap(or any other type of music) on a 2.1 set up(bookshelves/sub). Anyone with experience with this? How is the bass with 2.1(bookshelves/sub) compared to a standard sterio set up(towers/woofers)?
I don't know an exact budget right now, but I consider it to be a low budget, if you can make your recommendations for lower budget system.
I looked at this design by Wayne J. Dayton 3 (http://speakerbuilder.net/web_files/Projects/D3/dayton3.htm)
I was thinking about using these for fronts/rears but then I thought using them for rears might be overkill.
I really wanted towers for the front so i got this link for Dayton 8's
http://www.wadsnet.com/~dtenney/dayton_8MTM.htm
I was told I could reduce the cab volume to 3.4cf from 4.4cf, which i would use to cut down in the depth.
Hopefully I can take a look at some of your recommendations for a set up or at least fronts/rears. Thanks for viewing/replying to the thread!
My experience with the Dayton Classic drivers:
The Dave Tenney D8MTM is OK but I found the recessed midrange unbearable. I finally crossed it at 500 hz and the vocals came out fairly well. I used the Hi-Vi B1S mid/tweets to accomplish this, also the box is a Dual-Chambered Reflex.
http://img.photobucket.com/albums/v641/rjakubin/Dual-ChamberReflexBox-1.jpg
http://www.diysubwoofers.org/prt/dual_chamber.htm
http://paginas.terra.com.br/educacao/claudionegro/english/
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=297-411
http://www.madisound.com/cgi-bin/index.cgi?cart_id=8881884.19926&pid=1005
I didn't try the 6 1/2" but I did build a 5 1/4" . I put the 5 1/4" in a Transmission Line box with a Seas H1212 tweeter. If your looking for towers and the Dayton Classics take a good look at DBrowns site.
He has two versions of the db616tl. One with the 6 1/2" Dayton Classics and his upgrade with the Dayton Reference Series drivers - the db717tl;
http://users.d-web.com/dbrown/db616tl2/db616tl2.htm
http://users.d-web.com/dbrown/db717tl/db717tl.htm
My test box 5 1/4" TL;
http://img.photobucket.com/albums/v641/rjakubin/DaytonClassic5sSeasH1212.jpg
http://img.photobucket.com/albums/v641/rjakubin/My_Labyrinth.jpg
My line came out to 112" in a bookshelf box.
The D3's are also a good choice for a 5.1 - The one being a subwoofer. A lot of DIY'ers like the Dayton Quattro line.
The bottom line with the Dayton Classics are that they have an excellent bottom end. My 5 1/4's really surprise me everytime I play them. The mids are a little lacking in detail but all around are quite musical. A good bang for the buck speakers.
As you can see they'res quite a bit of different box styles you can put these in. I like towers and I like Line-Arrays the best.
http://img.photobucket.com/albums/v641/rjakubin/Speaker-1.jpg
Hope all this info helps in some way, Rudy
Others comment on these speakers;
Posted By: Ken Taillon <ktaillon@wesleyan.edu>
Date: Monday, 22 November 2004, at 12:26 p.m.
The MTM using a pair of Dayton 6.5" woofers and a Vifa d27 tweeter. The boxes took a while to get everything just right. This was the first set to incorporate the grills into the front baffle.
They have a very flat FR, maybe the grills are helping. Now I wished that I used better drivers. The bass and highs are great but the mid's are lacking.
The blue grill cloth is a compromise with the wife. I also made oak stands to match
http://focus.its.wesleyan.edu/gallery/album04/128_2838_IMG
Posted By: Jason <jkandreasen@hotmail.com>
Date: Monday, 22 November 2004, at 12:49 p.m.
In Response To: Re: Since everyone else is posting pics....DIII PI (Ken Taillon)
They are the buyout ports - I wish I had bought a case of them. Exceptional port.
The tweeters are the Dayton 1-1/8" "silkies". There hasn't been much buzz about them lately... they must be old news now.
I suspect these will have the recessed mids yours have. That's one of the known shortcomings of these woofers. They pack a big punch on the low end, but the midrange detail just isn't quite there. I plan on using them as surround speakers, so they'll be fine.
Jason
Jason
