Hi Guys,
I purchased a pair of ms10i pearl addition speakers from ebay and upon testing unfortunately found that one has a blown tweeter so I am wondering if someone could recommend a replacement tweeter as I know it is of a fairly common spec being an 8 ohm 25mm aluminium Dome.
I am on a budget with this project so do not want to spend too much.
I know some cheaper tweeters can sound harsh but the spec of the ones in the below link sound quite good and am wondering would they do the ms10i any justice?
Black 50w 25mm Titanium Dome Tweeter 8ohm - CommsAndSound.com
Any advice would be much appreciated as always 🙂
I hate working with tightwads. You replace with something that has a possibility of a good result primarily. You appreciate that you must replace BOTH tweeters? 😀
Pearls of hi-fi
Do either of these look like they might fit with a bit of cardboard to fill the gap? The second is better but might need attenuation.
H0532-08 19TAFD/G
http://www.seas.no/index.php?option=com_content&task=view&id=79&Itemid=103
You need to measure the oval tweeter plate and magnet cutout.
Pearls of hi-fi
H0532-08 19TAFD/G
Hi
Thanks for the reply.
Oops I forgot to add that i will be replacing both tweeters.
The reason for me being a tight wad is that these speakers will be set-up in a room in which these speakers will occasional use from myself.
I thought i'd get stick for being on a budget and also knew the big brands with their big prices would turn up in this thread lol.
The seas units look superb but they are around 30-40 each 😱
I will check all the dimensions of the existing units today.
Is there not a budget tweeter that is known to perform well?
Hmmm .......
With the rectangular spacing of the domes screws
nothing is going to fit the standard mounting plate.
So your going to have to cut down a round tweeter.
TBH the linked to cheap tweeter, at allegedly 98dB, might work if that
spec is wrong, or it might be a very grim device. The Fs at 1.8KHz, if
its well damped (making ferrofluid mandatory) might suit the MS10iP's
simple crossover, but undamped it could be a general disaster area.
Very likely it will work very poorly, cheap tweeters are a crapshoot.
Seems to be : http://www.bluearan.co.uk/index.php?id=EVNL063L&browsemode=category
TBH one duff tweeter wipes a huge chunk off the value of a used
pair of MS Pearls because to be safe you must have the original
tweeter, that is specifically designed to use a single capacitor.
The tweeter in no way has a "common" specification, e.g. it
has low sensitivity, to avoid the use of level matching resistors.
(If its the same unit as in the MS20iP it might have resistors.)
Seas used to make a tweeter designed for a single capacitor,
(very low Qts), but not anymore in the available range.
eshop - Speaker Spares - Mordaunt Short
Tweeter here is the wrong spec and £64 a pop !
I'd insist on an ebay refund, unless bought dirt cheap as seen.
rgds, sreten.
rgds, sreten.
I agree with the comments on here and would love to get a decent spec or the originals but can not seem to find the spec of the original tweeters anywhere 🙁
The model number on the rear of the tweeter states:
91000899306
I picked the speakers up for £18 but the seller gave me an £8 refund so I thought it would be worth attempting to get them fixed as they only cost £10 and are otherwise is superb condition, it seemed like such a waste to throw them away.
I guess I could keep the working components as spares and try to source another set of working ms10i speakers if this attempted project goes belly up.
91000899306
Those replacements are NOT £30-40 a pop! 😀
Seas
Seas Tweeters, Prestige & Excel ranges, Free UK Delivery
You just gotta figure out how to get them to fit. I'd give the broken tweeter the 1.5V battery crackle test first. It might not be totally dead either. Might just need a teeny weeny wire resoldering.
I'd reckon it's worth fixing the MS10i. Nice plastic bass unit. You should measure its DC resistance first to establish if it's 3 ohms DC (4 ohms nominal) or 6 ohms (8 ohms nominal). Then can sort out a crossover upgrade too, based on the more sophisticated 4 ohm plastic bass Epos ELS-3 which was in the Robin Marshall stable. First order kinda sucks unless you like BRIGHT. 😎
Nothing hard about this.
Seas
Visaton has an oval tweeter: G 25 ND - 8 Ohm
whether it's the same 'ovalness' - eccentricity??? is a moot point though... & probably to expensive for this job
OK guys, lets keep the personal stuff and ping pong arguments out of the thread.
System 7... you might like to repost your last pictures.
Thankyou, Mooly. Alas so much good stuff lost, I don't think I can reprise it briefly...🙁
Now back to the suggestion that jazzbee might try the affordable Monacor HT-22 Cone Tweeter. Discussed here:
http://www.diyaudio.com/forums/multi-way/217672-monacor-ht-22-a.html
I'd think the original 2.2uF and 47 ohm treble filter could work well with no modification. I had a good time with these MS10i speakers, and a cone tweeter might work very well.
The ideal scenario is sourcing another pair with the same problem for
a similar price and ending up with a fully working original pair for ~ £20.
You can then decide whether is worth fixing the non-working pair.
Finding another working pair for ~ £20 is still an attractive option,
such are the vagaries of buying used stuff at very low prices.
Fully working but tatty cabinets would be a good find.
The cone tweeter looks very ballpark, though no impedance curve
means you don't know if that is going to be an issue with a simple
series capacitor. If the cone tweeter needs attenuating then you
may also be able use this to suppress any tweeter driver impedance
peaking to an extent - a decent solution could be possible.
Still, IMO the best option is a fully original working pair.
rgds, sreten.
AFAIK the Pearls are the earlier models with inferior cabinets
and lacking their plastic rear baffles, the same front baffles.
The best score would be a pair of MS10i's.
rgds, sreten.
Hi Guys
Anybody knows if MS10i Pearl speakers can be used with Denon PM-100M? Or is it to powerful for them?
Hi Guys
Not a problem with sensible use.
rgds, sreten.
- Recommend a MS10i replacement Tweeter
