VISATON B200 Aperiodic Full Range Speakers
TBORZIC
I finally found a bit more detail and some photos...
According to the builder, an "aperiodic" configuration is halfway between open baffle and bass reflex.
(Personally, I would see it has half-way between closed and vented...)
The driver is a high efficiency open baffle designed unit .
Page not found | Visaton
-ohm
Based on the Omega Aperiodic 8 speakers.
6moons audio reviews: A winning system's approach by RedWine Audio, Omega Loudspeakers & Audiopath
MDF construction, damped inside walls with felt type material and wool stuffing. The cabinet is H600mm x W400mm x D300mm
There are 3 resistor/type vents (4 weren't available) that can be installed into the rear 100mm vents. These tighten up the bass, if required.
These sound remarkably good and image so well, with a SET low-power amp.
Do you, by any chance, have some more details about this setup? Photos, drawings, etc..
Thanks,
T.
TBORZIC
-ohm
