Rebuild LM3886
I am rebuilding my LM3886. The goal is this one is to drive bass speakers (H frame with 2 Alpha15a per side, xover 12 db at 180 hz).
I changed toroid for a 300 Va (20 volt), add a safety loop breaker and checked the mounting of course !
I have LM3875 too, and for me it's sound more "warmer" than LM3886.
I do not say that it is the truth for everyone but maybe it depends of speakers, music, and taste.
I found this :
http://www.diyaudio.com/forums/pass-labs/103050-jfet-boz.html
jfet Boz small from Nelson Pass (mess 2). I have SJ74, so maybe I can use it ?
Or do you know another way to make LM3886 a little more "warmer" ?
Phil.
Hi ivandezande,
You are right, it has not zobel, only serial 0,1 Ohm at output..
But what would be the effect of a zobel circuit for low frequencies (35 to 300 hz in my use) ?
Phil.
Good point, I did not catch that. However, in case you ever use it for full range, I would say it's good to make sure everything is there for stability in the future.
