as always: here's the newby wanting everysthing for nothing🙂
I have a philips cd304 mkII (customized)
and a pair of b&w 601 s2 (upgraded)
Now i am lacking a good amp. wouldn't it be sweet t have a tube amp!
can anybody point me to something simple yet powerfull enough (please nothing expensive or fancy)
i'm eternally gratefull!
Bas
Bas
Costs rise rapidly with increasing power O/P. Good O/P transformers are expensive.
Unlike SS, you can safely use the full O/P of a tubed amp. The approx. 35 WPC PP EL34s yield might be enough for your speakers. If you think you really need more power, a compromise to consider is a tubed preamp combined with a SS power amp. As the 2 V. O/P of a CDP will drive most amps into clipping, all that is required is a buffered (cathode follower) level control. "Games" can be played with a cathode follower's load resistor that cause it to generate some 2nd harmonic distortion. A LITTLE 2nd harmonic distortion added to a CD only system with SS power power amplification is, IMO, desireable.
calling Shifty
Hi Shifty,
any idea where you can get old valve gear in NZ? Im in NZ and wouldnt mind trying a valve amp some time but cant source transformers valves etc.
cheers arthur
Hi Shifty,
cheers arthur
I'll once again plug Revision 3 😀
http://webpages.charter.net/dawill/tmoranwms/Elec_Revision3.html
Tim
Tim
- Tubes / Valves
- reasonable powered simple amp
