EnvisionAudio said:
You mean $$$$ technology, right? 🙁
I mean cool in the sense of producing little heat 😉
EVA...
May I respectfully ask what you do for a living? I know, having lived in the U.K. for many years, that this is a rude question. I do not, however, mean to be rude, just unavoidably American I guess 🙂.
I, myself, am an ex-ferrari engine builder - options trader - n/dimensional data architect who happens to have a suicidal audio habit.
Your advice is so focused and precise that I had to ask.
Mor importantly, what do you listen to?
(I see that this thread is already hijacked by the *horn* club so I don't feel bad)
Tom
Tom
Since this thread is now about SMPS's, would this be an option?
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=3100226867
Maybe you could have 4 in series and go for a +-48v setup like a 41Hz amp2?
FYI:
Sergio has two articles in the current issue of the German elektor:
http://www.elektor.de/jahrgang.46744.lynkx
Charles
Charles
A friend of mine have had both amp and smps blew up on UK 240V because they werent tested above 230v.
Conclusion, coldamp is %$@!!!
Usually 220 and 240V should not make such a big difference?? Are you sure you did not connect it up wrongly?
All our PSUs are tested up to 260V and their reliability is extreme, so high that it is even used in military environments.
The cause of the problem that your friend had must be determined , but I think that it would have been more appropiate to contact and inform us about the problem so we can help him, before posting such taxative and negative comments, don't you think?
Of course, if it is due to a manufacturing problem, we will replace it happily.
ssanmor said:I think that it would have been more appropiate to contact and inform us about the problem so we can help him, before posting such taxative and negative comments, don't you think?
...and coldamp takes the moral high ground
Tekko said:A friend of mine have had both amp and smps blew up on UK 240V because they werent tested above 230v.
Conclusion, coldamp is ****!!!
As I am a Swede as well I feel a bit ashamed of the not too tentative assumption.....So you have any proof to present us with or is it just some unproven hypothesis?
Hi everybody,
Ok, but if we forget the political issues, what about the amplifier, did someone compare them to icepower or ucd or even tripath ?
AAE
AAE
phase_accurate said:There was some test of several class-d modules in elektor recently.
Charles
Only measurements unfortunately which I regard as a help to exclude the bad ones but is insufficient to find the good ones.
- Class D
- Real opinions on Coldamp
