Real Expert or Just Self Proclaimed
When we hear low frequency sound do we need to stand still to catch all of the wave? Do we need to be a certain distance away from the source to hear it? Is our perception of the tone in some way compromised by the fact that we are only receiving a very small portion of the wave? How does the ear drum work? By vibration from sound waves bouncing off of the membrane, that's how. How can a low frequency sound wave bounce off an eardrum if it is unable to reflect from a solid object?
What we hear is a change in pressure. The wave propagates as zones of compression and rarefaction, i.e. pressure differentials. We detect the change in pressure against our eardrum. We also detect the change in pressure between the inside and outside of our chest.
Sy you lament the education system, so do I but I really have a problem with people who absolutely refuse to look at the logical evidence presented and hold fast to ideas that they can't explain themselves.
I'm waiting for someone to prove me wrong here. You can repeat that same chant over and over again - I'm not buying it.
John, doesn't all this sound a bit familiar? Remember the discussion about sound traveling as a compression wave in water? We are heading down the same road and will arrive at the same destination.
Sheldon
You can't catch all of the wave, it's bigger than you are, even when you're in heels.
Leave those photos outta this. 😀
So, we don't catch all of the wave yet we can perceive what the frequency is...interesting. How can even just a little bit of the huge wave make it inside our ear canal and bump up against our eardrums? How can it move the eardrum unless it reflects off of it?
It's been a while since I've had a knock down drag out discussion.
I prefer to think about things and postulate my own ideas sometimes, rather than just sitting back and either living in ignorance or accepting everything I hear as fact. Inquisitive mind, you know?
BTW if you are implying that I embarrassed myself during the "water debate", you are dead wrong.
I caught this on on the head - not all of it, but enough. Well, actually didn't quite catch it, as you can see. But I did feel it. Frequency was about 17 seconds.
Sheldon
We were all friends after the water debate. The phase changes of water are not very intuitive, I finally found a contradiction that made only one path possible.
You got me on what is known as (in the Law and Order type programming) a "technicality" that only fits with the peculiarity of water at a specific temperature.
No matter. I'm gathering data for round 2...😀
In the meantime, anyone want to explain to me how a low frequency sound wave can go around a bend in a pipe without reflecting?
The "wave" doesn't go inside your ear. The air pressure outside your ear changes.
Because the the sound wave is a series of compressions and rarefactions, (changes in air pressure), your ear drum moves.
Really high frequencies might reflect in your ear canal or reflect off your eardrum cuz their wavelengths are short enough to fit in there. But with long wavelengths all you get is the pressure effect. Nerf ball, right?
Something wrong with the "quote" thingy.
I tried to avoid that implication in my phrasing. I was pointing out the parallels. In that thread, you held on to an intuitive impression, because it fit with your personal experience. That's not a bad starting point. The physics and math that explained the phenomenon require some background to completely grasp. Not everyone has that. Again, not a problem. But a number of people tried to bridge the gap between the well known physics, by presenting the math and some analogies to spark the intuitive process. These attempts were dismissed at every turn, in your words "over and over". People have studied and made the effort to master some of these things. If you haven't, fine. Everyone has more gaps in their knowledge than bricks. That's where teachers come in. But a teacher can't make anyone learn. The student has to want to learn, and make the effort to understand what is being taught.
Sheldon
I assume you have worn headphones? Or earbuds? I have a cheap pair of Panasonics but they are pretty good at low frequency reproduction.
The transducer moves in and out creating a wave. The wave (impossible as it may seem) contacts and reflects off of your eardrum. Now call the wave whatever you like: pressure, compression, rarefaction, there is still an energy transfer which is a physical thing.
If a low frequency wave cannot act on the sidewall of a pipe (let us have it your way - pressure) then it cannot act upon the membrane of your eardrum.
:cop:
Guys, We need a new name for this thread, agreed?
Suggestions please.
"TL design and other catastrophes"
Now that it's starting to look like This Thread, maybe it should be moved to the lounge or bunged under "everything else".
Which reminds me...
If you throw a 4" nerf ball in a room, it will bounce around. If you stuff it down a 3.5" mailing tube, it's not going to bounce off the walls of the tube.
If you put the nerf ball behind the airplane, will it help the plane take off, or just bounce off?
Either way, it answers one of these arguments.
Sheldon
Well put. Maybe this thread will amount to something. So far its been pretty narrow ...
