ready to mod the hell out of my asl wave 8's
There was an article published sometime ago (can't remember where----"senior moment") that recommended replacing the coupling caps, I believe the author used Auricaps, and was impressed with the result. These are single tube (6Bm8) if I recall correctly.
Pete
Here are the specs and schematic - I also own these and interested in some tweaks. Previous owner replaced the Illusion capacitors with (Jensen .22uf/630v oil caps bypassed with .01uf Vitamin Q's).
Many thanks... Nate
Ok, some general suggestions in $$$ order for your amp:
1) Nichicon Muse or Elna Cerafine cathode bypass capacitorss on preamp/ power amp tubes.
2) Ultrafast power supply diodes and better power supply caps.
3) Inductors in the power supply (say 5-10H 80mA) between first and second cap ( remove the resistor)
4) better output transformers
ECL82 is a nice sounding valve. 😉
