It's been a few year since I build my dipoles. I build them with an H-baffle for the woofers (Dayton 15" IB, one per speaker) and "straight baffles" put on top of the woofers housing so to speak Dayton Reference 7" alu and B&G Neo 8.
Woofers have been actively filtered via a DCX2496, the mids/highs passively filtered.
I haven't measured them or anything. I just really liked how they sounded.
Now I have had to get rid of the 200W/8ohms per channel powering the woofers some time ago and driving them with an Arcam Alpha 8P and a TA2022 amp isn't really the same.
I also need to minimize their footprint in the room, so I thought I might go from separate baffles to one for all three elements and making it very tall(?).
I'm not a speakerdesigner by a longshot, I got lucky when building these.
Anyway, would a plain OB that's about 50cm wide and, almost, however tall it needs to be work? 50x180cm wouldn't be a problem as an example.
I was thinking of having the baffle leaning slightly "backwards".
It's been so long since did anything with speaker DIY that I've forgotten how I calculated from where to add compensation, where to put LP and HP for the woofers etc.
I don't think I've used the DCX to it's potential as I haven't measured the room etc, but I'm thinking about buying or building a mic to measure via REW that I recently found out about doing some research for the re-design.
I'm grateful for any and all help in this endevour.
Woofers:
Dayton Audio IB385-8 15" Infinite Baffle Subwoofer
Mids:
Dayton Audio RS180S-8 7" Reference Shielded Woofer 8 Ohm
Highs:
Bohlender Graebener Neo8 Planar Transducer
Woofers:
Mids:
Highs:
