rd75 and cxr22
Hi all,
I have just taken my RD75s out of storage (been wrapped up for over 8 years:-(
I also have a Clearview CXR22 Xover for use with these speakers, problem is I have lost the idiots guide! Can anyone tell me if this xover has the B&G recommended 'notch filter' built in or do I still need to fit that inline from the xover to the ribbon?
If anyone has the xover instructions I would really appreciate a copy.
Cheers
Tom
Hello Tom,
I hope you find the attached documents of use.
regards,
Keith
  • Clearview CXR-22 Manual Part 1.pdf
  • Clearview CXR-22 Manual Part 2.pdf
  • Audio X Stream Site.pdf
  • Clearview CXR-22 Response.pdf
I have a few woofer choices available to me and to be honest 400Hz is a bit high but to be able to vary between 150 to say 350Hz with just a few component changes would be good, but knowing which components is the question.
cheers
It takes me literally a second or two to make that change. I use a DCX2496. I have a line array of six Monsoons that acts a bit like the RD75. I've settled on 240 Hz after lots of listening and measurement.
