rcd-965bx problem
I have this rcd-965bx cd player which seems to have this problem.
Whenever I insert the disc into the player, the disc spin very fast the other way round.The laser unit is cdm4. Is this one of the sympton of a failing laser unit? The chips used were saa7310- saa7220- saa7323 and I'm thinking of modding it to non-os with Tda1543. Is it possible?
Similar problem.
Hi Tonitze,
I came across something faintly similar.My Marantz CD67 SE mkII stopped rotating. The disk would not rotate on insertion into the machine. When I put it into service mode the disk would rotate at high speed in the opposite direction. IIRC the CD67 also has SAA chips.
I tried all kinds of things. Finally I found a "laser assembly" in the local market at a very affordable price. So I bought it and put it in. The machine now works fine.
Note that when the machine was faulty I could still see the laser light up. So something was drastically wrong with the assembly.
Maybe you have a similar problem. The laser comes as an assembly which fits into the middle of the transport ( about 5cmx8cm). There are no adjustments to make. There was only one connector (flexible) cable on mine.
Try SimLim Tower for a spare laser assembly.
Ashok.
