Hi there,
I recently built a RCA switch, something similar described in this tutorial: RCASwitchBox - ElephantStaircase .
While it works great for the vinyl player input, it doesn't work at all for the computer input
. In this latter case, a jack-to-RCA cable is the input in my RCA switch.
I think it's a ground problem. It's worth knowing that in my circuit I have wired all RCA negative poles to the same ground node by a plastic wire connector. Do you think it's the way to proceed? Do you have any other idea about the cause of the problem?
Thanks for helping!
Alex
Thanks for helping!
Alex
It's standard to connect all the shield/ground tabs on the jacks together, and just switch the 'hot' or 'signal' lines.
Do you have a wire with alligator clips on each end? Bypass the switch by connecting the computer 'IN' signal (RCA center conductor) to the 'OUT' jack with your test wire.
Or, use a female-female RCA connector to connect the RCA computer cable to the amplifier cable...
Or plug the computer cable directly into the amp
Does it work / play music? If 'Yes' then it is a switch connection problem.
If 'No', then check your computer 'Out' connection,and soundcard settings to make sure you are pumping signal out of the computer.
Check the switch connections with a test light or multimeter (needle-type) on OHMs to make sure the switch is working the way you think it is.
You can figure this out- just be logical.
Oh, and PLEASE do a better wiring job than the other builder did, as the picture shows. You don't need all those big loops of wire jumbled together in your box!
I would be a bit concerned if you are switching the low-level signal from a turntable and the (higher) line output from a computer or CD player - be careful to set the levels properly.
John
PS- By plastic wire connector, you mean a 'wire nut' aka Marr connector? That's OK for testing, but better to solder wire from jack to jack, connecting the 'ground'/'negative' tabs. Depending on the jack spacing sometimes you can solder the tabs from a pair to each other.
Thanks so much guys!
I figured out the problem, this was related to the ground, problem lied in connecting negative poles. So I "properly" connected negative poles together, and, tadaaaa, it works like a charm!
@(kevinkr,VictoriaGuy): yeah, by a "plastic wire connector" I meant a Marr connector!
@VictoriaGuy: when you speak about being careful with in-channels like turntable/computer/etc.., do you have any experience/reference to problems that can occur?
Last point, but not least: I now plan to build a sound-inputs mixer, do you have any classic schematic for that?
Thanks so much once again!
