Could someone take a look at this circuit and explain the biasing arrangement of the 6AU6 tubes.
Specifically what is the purpose of the 330k resistors between the 1 MOhm Rg resistor and the 1800 Ohm Rk biasing the cathode.
The fact there is even a resistor between them is confusing me.
Thanks in advance.
Link: http://www.oswaldsmillaudio.com/images/rca museum pics/archive pdf's/SP20 Amp Manual.pdf
Thanks in advance.
I think this question came up in another thread a few months ago. Did you search?
The cathode resistor, presumably used for degeneration, generates more voltage than is required for valve bias so the grid is attached to a potential divider formed by the 330k and 1M.
Most circuits either ground the grid (for DC) or pull it up to a significant positive value. This circuit does not, it pulls it up just a small amount, so it looks strange at first sight.
