RCA Solid State '74 Databook
I'm looking for a copy of the RCA Solid State '74 Databook Series; Power Transistors and Power Hybrid Circuits (SSD-204B) - principally the schematic of the ~40W quasicomplementary amp.
Lot thanks,
Donk
i have the book, and there is no description of the amp given, but there is a list of specs for the amp and a distortion curve and freq response curve. that's it.....
power out:
40W/8 ohms
55W/4 ohms
distortion:
1% THD at rated power
0.1% IMD 4:1 60/7khz at 4W
sensitivity:
600mV for full output
hum and noise:
-80db input shorted
-75db w/ 2k terminated 20ft cable
input impedance:
20k
freq response (interpreted from graph):
-3db at 5hz and 100khz
-1db at 10hz and 50khz
that's all there is. the amp is shown only as a "typical application" for two different transistors with no other description given.
the application notes in the book are geared toward linear and switching regulator design for power supplies.
