Can anyone recommend decent (but not too expensive) chassis mount RCA jacks that I can order online?
Thanks.
Thanks.
Not cheap, but really good quality:
DH-Labs CM-R1 RCA Socket
Only one inconvinience with them - nut is from inside - so, first it should be mounted on schassi, then soldered. If you need ro remove board - you must unsolder wires, but not just unscrew nut and take it out from chassi with the board.
Do not recommend to use Neutric unless you intend to save the money. After some time gold-plating is scratched and there will be some dark scratched matherial. Also be carefull with stuff rom eBay - there could be written gold-plated copper, but they will stick to magnet or will be some light alloy with alluminium inside.
- Design & Build
- Parts
- RCA jacks
