I am searching for a device that will enable me to switch between one source (Node 2i) and run the signal to either my Yamaha AS1100 or to an Elekit tube amp. I see plenty of devices that allow multiple inputs to one output, but can't seem to locate the opposite...
I wouldn't mind building one myself, but I'm not that experienced with electronics to both develop and build. Any kits? Or just a device I could purchase?
Thanks!
Thanks!
An un-powered selector should work both ways.
Example -
https://www.ebay.co.uk/p/1304306252?iid=351457314573
Connect your source to the output.
Connect amp 1 to aux 1, amp 2 to aux 2.
If you wanted to build your own (hardly worth the bother) then 3 pairs of RCA sockets, a 2 pole, 2 way switch and a box.
Example -
