Rca 6md8
Any element that is capable of amplification can be turned into an amplifier, but man, is this one oddball choice for audio or what 😀 Common cathode for all three sections, rather low mu, modest current capability per anode, not very linear 🙁
Can you be more specific regarding your idea, namely what kind of input (voltage swing) and what kind of output (load) were you planning to use with it ?
It's basically 3 6GU7's (similar to a 12BH7) sharing a common cathode. Used primarily as a color matrix amp "color driver" for color picture tubes, so it's fairly linear. Take a look at the curves for a 6GU7. Except for the shared cathode it would make fine all in one input tube for P-P amp. Too bad as I have quite a few of them!
Wayne
The thing is considerably bigger than a normal 9pin signal tube. And needs a special 9 pin NOVAR socket.
(y tiene el chupete en la parte de abajo)
