RB 971 MKII with tubes
I've done a bit with my 971 (Mk I) preamp section:
- replaced the opa2604 with op2134
- bias the 2134 to class A
- improved the power supply to the linestage
- improved the dc block caps; bypassed (shorted) the second set of blocking caps
The weak link is probably the volume pot, but I can't get a suitable replacement that will fit.
Having done this, I think that if you want to proceed with a tube linestage, take the signal just after the attenuator, then shunt it back where the 2604 would have fed the signal onwards. Otherwise, just bypass it all, and use the 971 as a power amp. BTW, the mods above work very well.
