Hello, I'm trying to repair an Acustik power amplifier.
Model RZR1-2500D
The problem is that when the volume is increased beyond a certain level of sound demand, it intermittently goes into protection mode.
I have no idea what causes this type of failure.
HFP50n06
FDP2552
The amplifier has integrated circuits such as
SG3525AP
LM393
IRS2092s
Can someone help me with how to address this problem? Please.
Thanks for you attention
Model RZR1-2500D
HFP50n06
FDP2552
SG3525AP
LM393
IRS2092s
Will it shut down when driven to clipping with no load?
What about with a load significantly higher than its lowest rated load?
Could it be due to voltage drop at the 12v input (low voltage protection)?
with and without load. causes the faultWill it shut down when driven to clipping with no load?
The fault persistsWhat about with a load significantly higher than its lowest rated load?
The voltage variation is from 13.79v to 13.62v with a consumption of 18amp with a load of 2 ohms in audio output a tone of 60hzCould it be due to voltage drop at the 12v input (low voltage protection)?
Just like that, the daily use amplifier started to give that problem.Was the amp working perfectly for a while and this started after it had been OK?
You stated that it intermittently goes into protection. Does that mean that it sometimes plays normally?
Does it play normally at low levels?
- General Interest
- Car Audio
- Razor RZR1-2500D
