Back! Yeah I agree to change the title to Volumio... Maybe the mods can help on that.
And, regarding Volumio for UDOO. Don't worry, the update is coming. I am just active on lot of fields right now... So, please be patient.
I have the 1.3 UDOO version ready, I'm just testing it prior to release. Pinocchio, you won't regret to have choosen it...
I was also asked for i2s output for UDOO. Unfortunately there is no i2s driver yet, hope that someone would hop on that and help...
Thanks, that is really appreciated!
Do
Hi Michelangeloz
Is Cubieboard3 / Cubietruck implementation within Volumio planned ? There is I2S capability, I do not know if useable. It is priced 96,5 € in France which seems competitive.
Anybody has an experience with this board ?
BR
Jean-Louis
Hardware Specs
BR
Jean-Louis
Hardware Specs
- AllWinnerTech SOC A20 ARM® Cortex™-A7 Dual-Core ARM® Mali400 MP2 Complies with OpenGL ES 2.0/1.1
- 1GB/2GB DDR3@480MHz
- HDMI&VGA 1080P display output on-board
- 10M/100M/1G Ethernet
- Wifi+BT wireless connection with antenna on-board
- SATA 2.0 interface support 2.5’ HDD (for 3.5’ HDD, only need another 12V power input)
- Storage solution NAND+MicroSD or TSD+ MicroSD or 2*MicroSD
- 2 x USB HOST 1 x OTG 1 x SPDIF 1 x IR 4 x LEDs 1 Headphone 3 x Keys
- Power DC5V @ 2.5A with HDD support Li-battery & RTC
- 54 extended pins including I2S, I2C, SPI, CVBS, LRADC x2,UART, PS2, PWMx2, TS/CSI, IRDA, LINEIN&FMIN&MICIN, TVINx4 with 2.0 pitch connectors
- PCB size 11cm *8cm*1.4mm very suitable for installing a 2.5’ HDD
Hi Michelangeloz
BR
Jean-Louis
Hardware Specs
Hi all
no user for the Cubietruck ?
For udoo user I suggest to use the hidden usb port with your dac.
The connector is in the udoo starter kit but I thing it is avalaible also in udoo shop as single cable.
Pheraps it is only in my imaginary but I thing this is the more musically usb port in udoo.
Inviato dal mio SM-N9005 utilizzando Tapatalk
I have a CuboxPro and Cubox-i4.
I am not aware of an I2S output, maybe internally (if you open and break it out).
For sure, there is a TOSLINK (optical S/PDIF) output.
I have tried:
- works but "strange":
- my TOSLINK receiver tells me: "signal with Emphasis" and
- I have to lower the volume drastically (SW Loudness), otherwise just distortions,
audio is not very loud then
BTW:
My Cubox-i4 comes with Android. I do not have found a way to configure TOSLINK audio out. I have installed XBMC for it, works, and I was able to configure once the audio to have TOSLINK working).
To try Volumio on Cubie would be nice.
Best regards
Torsten
I have tried:
BTW:
Best regards
Torsten
Hi all
The release for Udoo was ready, then I discovered a bug which required mpd to be recompiled (and for some reasons, it didn't recompile on my dev environment) so it is a little delayed.
After that I'm making the cubietruck porting, which is complete, exept for the kernel which I have to recompile, and throws errors which I have to further investigate...
So sorry pinocchio if I'm making you wait so long... But sure it will be worth it...
Yes, I can confirm this. Also, for a really strange reason, it is the USB port which can be handled by jack audio server in pre-emptive mode...
Maybe if we look at the schematics we can understand why...
Hi mikelangeloz,is that the version for cubietruck will be compatible with Ibox (Allwinner Technology A20 Dual Core) https://www.indiegogo.com/projects/ibox-mini-multi-function-single-board-computer
Thank.
Thank.
Thanks!
If you want Volumino to run on other Hardware please send Mikelangeloz the inventor diyAudio - View Profile: mikelangeloz
the original hardware or the amount of money he needs to buy this hardware plus shipping plus other necessary hardware items.
So he can test it on the hardware and build in some tweaks.
Tracking down noise sources on a Raspberry Pi | Crazy Audio
I run the Raspberry Pi as a high-end network player directly with Ethernet cable via a power-line adapter.
I was initially a little sceptical, but after I have tested different USB with external Jitterkiller and Isolator on the Laptop, I changed to the Raspbi.
Sounds good. The DAC hardware is also just the finest.
I do not need special drivers, because the DAC has its own controller. Just one input configured as I2S for Raspbi .
There is no problems with Noise, although my quick and dirty measurement set-up is not really beautiful. I was really surprised because I had expected more noise.
The test signal (2 kHz WAV with-1dBFs) was played over the network.
Thought it could be better to continue on a Volumio topic, instead of going on with RaspyFi's one:
http://www.diyaudio.com/forums/pc-b...usic-player-embedded-systems.html#post3961338
Please continue here, and enjoy!
- PC Based
- RaspyFi/Volumio - Turn raspberry Pi into Audiophile audio Player
