Quick/temp connector that accept resistors leads?
I have a through-hole pcb with 2 resistors soldered, among other components. I need to defeat power to a downstream chip, and I can do this by pulling these two resistors. Is there a female connector that I can solder to the pcb at the resistor location, into which I can "plug in" the resistor leads as a means to quickly reinstall the resistors without solder? I'm thinking of something analogous to wire terminals that accept transformer wire leads?
