Quick questions for wiring mono mini speaker
Say I wanted to build a mini speaker with two drivers... and I wanted to use this: TPA3110 BTL Mono 30W Digital Audio Power Amplifier Board DC 12V 24V Amp Module | eBay little amplifier... and I'd be using a stereo source. Is it the case that 1) I can just gang the left and right channels together into the single input and 2) I can run both drivers from the one output and 3) I can use two 4 ohm drivers and they will be in parallel resulting in a 2 ohm load and 4) this amp will work with a 2 ohm load?
Is this how the wiring is generally done in a "halfinator?" Just checking... thanks...
Thanks! So if I wanted to add a volume control would it be like this?
[IMGDEAD]https://lh3.googleusercontent.com/2lCymEt04NspyPzXGfvVIyr6wgJ7j4HORL5VJhGCy3gxwESexJqNVrGVaS0fhOO3y-bHXAtIf13ZmPJ34MrcIwnZGQjRK3k4xlABeK_UwttJco8k6UVrsGyif94jrq76oI4mXUrA-m6KWBefp2lMkzwoGalJwbSb1YGNq-8qdGXrjsmlbB7XZqtic5kBOLBIDtMtDaWhekl2uUt4RL4sTurFNX6fTPp2MEqTXLlFwUqWy6ATa4z2UmeQTwD_pdLuGAodhRxmPQ7GMDRhVSayRkXbfHdtBKc4OxvPnEAmPfgjfpR8R5_oyHM7oISFo0FXPQAndPoaabhNJMVxDDwN-h4rI2-BH2FKEoaMySVqpLudEF7ltYq1EbiLzv6YfskkFAQ3PK127FXp7z-Cziorxq92w30ug2939SV1kG91TdkmaZVv6eQbrCPFbO7DyUb3xw0GScFilkdA53xGYiyjcJ2QPK6yl5NT8XM6C5gSJUdBqJkaIglj-Gxxn2CDoBCdCy0w8aFoz5zRmxNlGEAeKyeqljwcqaaKTVUdR4lrGzqu0jEVOOD3YeDGjW1dpnxnf1j_fQ=w1429-h804-no[/IMGDEAD]
