Hi K-amps,
I will have a look around. I see the 555 is direct coupled, no caps. It is very likely the 545 is the same. I personally don't like that since the variable input resistance will vary the base offset voltage in the diff pair. That and you may someday get a DC offset into the amp. yuk.
-Chris
