Quick Post - My Car Speakers
This may get moved to Car Audio, but the drivers I've used in my car are also often used in home audio, and I really just wanted to post the pics.
So far I've done the front doors - which have the Silver Flute W17RC38-04 6.5" 4 ohm woofer and the SEAS Prestige 27TAFNC/G (H1397) tweeter (Zaph/Linkwitz).
The woofers were a perfect drop-in in the factory location, with a few extra screw holes needing to be drilled. The tweeter presses into the slightly (and carefully) enlarged factory tweeter door panel cutout, and just looks cool.
The factory system is 2 ohm, bi-wire, and I used no crossover components - not ideal of course but with a factory crossover of unknown specs I'm not going to try to measure and calculate filters - not my area of expertise and they sound awesome anyway - excllent pairing of drivers.
The rears are 6x9 woofers plus tweeter (all factory garbage by the way), but are murder to get to, and that's next on the project list. I may keep the 6x9s as subs - they DO have good base, but in their current location I will drop in a Scosche SA-69 adaptor plate with the same woofers, but with the Vifa DQ25SC16-04 tweeter (also Zaph). This is just to save a little money and the tweets will bolt on to the adaptor plate, as opposed to trying find a way to affix press-fit tweeters in a non press-fit location.
When all four corners are firing it's going to be my mobile concert hall, but it already sounds great as it is.
Thanks for looking!
DQ25
I wager the Seas will sound better. I don't personally like the DQ25.
Wolf
Thanks for the tip - I'm sure that's true, and perhaps I should re-think and spend the extra money to have matching components and sound.
I'm sure there's a fairly easy way to mount the SEAS tweets on the adaptor plate - the cut-out area has several size selections, and I can attach a metal strip and bolt down the tweeter.
