I have an old Toshiba SD4900 DVD-A player. It uses a BurrBrown PCM1603 six channel DAC to generate the outputs on a separate PC board on the back of the chassis (got schematics). Perfect for some mods.
The DAC number appears to be unique to this player, the closest number that makes any sense is PCM1602 http://pdf1.alldatasheet.com/datasheet-pdf/view/85650/TI/PCM1602Y/2K.html
Just curious if there is a DIY way to add a "better" DAC output stage for improved performance, especially on the front/center channels. Tried search but didn't find anything obvious.
