Quick impedance matching question
Hi all,
I recently put together 6 class D amps to power a pair of 3-way array speakers. After much troubleshooting (thanks again) it was determined that the inputs could not share a ground without introducing noise from unaligned switching currents. The solution I found was using input transformers (Monacor FGA-40HQ) to float the ground on inputs. Two questions:
1. I am assuming the best placement of potentiometer will be on the secondary, not in front of the primary, right?
2. These xos have 12k/12k Ohm impedance. What resistance pots should I be considering. I have usually used 50k or 100k, but is there a protocol around determining this so as to maximize fidelity across the frequency range?
I should add, the source is a Behringer DCX, which lists output impedance as 160 Ohms at 1kHz.
Thanks for your help.
Gary
To drive a 12k transformer you want a low impedance. Pot is variable impedance depending on setting. The Beeringer can drive a 5k pot which will be 1.25k worst-case, probably as good as it gets.
Thanks for the advice. Alps makes a 6-gang pot with 10k resistance. I think that will be the best choice. Unless anyone knows of a 5k 6 channel log pot that would be more suitable for hifi volume application.
Thanks again.
Gary
