In my new house, the living room + kitchen is in 1 volume.
(Panorama pic taken from dividing line).
It's tiled, apart from a rug at the TV area. There's also a rug on order for under the diner table.
There's terrible echoing just while talking normally, and audio listening is not very enjoyable.
What could I do to improve this, without drastically altering the visuals?
I've found this Dutch company which can make acoustic panels (acoustic felt, but I don't know how good though) with your own pictures. Perhaps the right sidewall could have a couple of those.
Foto op Akoestisch Vilt - Een Duurzame Fotopaneel voor aan de Wand!
My room also is a bit ... umm ... special. Many windows, just like yours, and a hardwood floor instead of tiles.
A heavy woolen carpet between speakers and seats helped to some extent - just a first step, though.
Then I analyzed room nodes using Room EQ Wizard and a measuring microphone (less than 50 Euros). Using a Daphile server as my main audio source, I generated full range FIR filters based on several measurements for left and right channel separately, which I imported into Daphile. This solved most problems caused by room asymmetry and first order reflections on the windows.
If you're going this way, consider several hours / days of trial and error. Bass nodes are easy, full range is tricky. But it can help if you won't install a large number of absorbers and / or diffusors.
Anyway, I still consider to install at least broadband absorbers of maybe 1 - 2 sqare meters behind my main listening place. You cannot fix all problems regarding room acoustics by electronic filters.
These panels are somewhat affordable, available in white and grey and do a good job from 250Hz and upwards. They work a lot better than any rug and don't mess up your interior too much. Although you'll need more than ten of them easily. I would start with assemblies of 2x2 or 3x3 white panels on the ceiling, starting in the living area. The panels actually do work a lot better when suspended with an air gap of about 5-10cm from the ceiling. But that might be too obtrusive.
Consider using these at the walls too. Vertical arrangements of 4 panels in grey or white would blend in I guess. And if you look around on that site you'll find cheaper options too (the basic Flamex panels do fine too).
- General Interest
- Room Acoustics & Mods
- Quick fixes to this room?
