I * I * R = P
1.2 * 1.2 * 0.47 = 0.6768 W
So, 2W resistors are fine here (except if you have 4 Ohm speaker and you drive the amp to full power for long period of time).
Well I may hook the amps up to a 2 ohm speaker load at some point and I would rather be safe then sorry. I just happened to have 2W available. For 3w or bigger I need to make an order.
Does quality of resistor in this area matter much? Will you notice a difference between a sand-cast or something better? I am guessing not.
I don't like the good things to go to waste. You can put 2 x 0R47 in series and parallel them to another two in series. That's equal to one 0R47/8W resistor.
When it comes to quality, aim for low temp. drift and precision, don't waste the money on boutique parts...
I just found a local source of just what I need (no crazy shipping fees). I am going there tomorrow.
- Quick F5 PS question
