Perhaps I'm not searching with the correct keywords... I'm looking for quick connect/disconnect binding posts - ones that don't require reefing down on a nut to secure a good connection. I've seen these in the past in a publication somewhere and don't even know if they are still available. They had a special terminator for the speaker cable that mated with a special post. No, not banana plugs. Had some sort of lock pin which ensured they didn't pop out. Thanks for any help.
2 poles, 2 connections MONO
4 poles, 4 connections STEREO or you can bridge them for mono.
Were you looking for pin banana plugs?
speakon connectors
I think you might be thinking of Speakon connectors
http://www.avcable.com/Merchant2/merchant.mvc?Screen=CTGY&Category_Code=CONNSPK
