Questions regarding the 2.5 clone
hi guys,
I've decided to try builed the colne, it seems to me that this is a cost/rewarding project which was tested by many people and gets good reviews (I'm using both Linn Mimik and Thorens TD166 as source and WAD 6550 + WAD phono II).
I read about the changes in the crossover design - I'm still confused a bit, what would you recommend ( trying to stay as close as possible to the real thing) ?
I've been searching for XO parts but could not find the exact components value, anyone can link ?
what do you think about bulding the XO outside the speakers in a small Chassis ?
What is the best way to builed the box? and in what stages ? should it be glue - is it enough ? how do you attach the bitum and the dacron to the box ? is it a good idea to make the drivers holes only at the last tage ?
I know it's a lot of question, I hope not too stupid, but I'm a comleate novice and would appriciate your help.
thanks in advance for any answer,
yuval
I opted for the "chinese" XO with the notch filter. The truth is that either XO will sound great. I used screws/glue to get it as tight together as possible. I left the back un-glued so I couls remove the screws and make changes to the XO as I felt nessassary.
The tricky part for me was the binding posts. I'd invest in a decent set of posts/bracket.
I plan on doing the veneering as a last step. I'd like to get the cabinet sounding perfect before I close it up forever.
