Questions on pulley and mod for BLWS231S-24-2000
Regards.
Somewhere, I had seen a pulley diagram for using BLWS231S-24-2000 motor with a flat belt. Not the cylinder pulley for use with o-ring types as VPI's, but similar to the one used by Sota.
Also, somewhere I had seen the information about the mod required to the motor wiring so it can be used with the 3 phase controller.
For the life of me, I have been looking and looking and can not find them again.
Anyone knows where to find these?
The diagram for use with flat belt and the wiring modification info?
Thanks for the Assistance.
Re: Wiring mod.
The motors come with 8 wires, 3 for the windings and 5 for the Hall sensors, the latter not being used. The 3 winding wires (Red/Yellow/Black) can just be used without modification. To remove the 5 Hall wires, the motor can be disassembled and the PCB with the Hall sensors can be removed with 2 screws. Make sure the wave washers that preload the bearings are correctly re-installed.
Re: Wiring mod.
Thanks Pyramid...... Last night I found that info again reading though the 25 pages of the " 3 Phase BLDC motor for turntable use?" thread ja, ja, ja
I have not been able to find the info on the pulley for use with a flat belt.
