questions on input transformers
1. How do I wire it for balanced/unbalanced input to balanced output?
I saw this guide from Lundahl's site (https://www.lundahltransformers.com/using-the-ll1545e/) on how to wire unbalanced/balanced input to balanced output.
Can I use the same guide for other manufacturer's input transformer ( example: Hammond 560G) that has the same "pinout" (unsure of the correct term to use here) as the LL1545e? Only asking since Lundahl's are not easy to find in my location.
2. I've seen 1:1 and 1:4 transformer? Are pros/cons to the different ratio?
3: How do I know an input transformer is suitable for unbalanced/balanced input to balanced output application?
I was just looking at the lundahl site, there so many input transformer (example: LL1544a vs LL1545a vs LL1690) that seems to do similar things.
Thanks a lot
1) Yes, if they have either two primary windings or a centre-tapped primary winding.
2) 1:4 increases the signal voltage by four and the impedance by 16. That can be handy when you have a very low level signal source with a low impedance and want to connect it to an amplifier with a very low equivalent input noise current, but not so low equivalent input noise voltage. Typical example: microphone preamplifier in valve technology.
Reactions: 1 user
@MarcelvdG another question please.
does the static resistance of the winding matter? Thanks again!
as an example (taken from the screenshot of the respective datasheets):
Thanks a lot
So what is the application?
Usually, unbalanced inputs are not wired with a transformer. But it can be done. However, not with the transformers you have looked at this far.
Output transformers can be used for input transformers. Some that are gapped would have a little bit of loss, but they all will work.
This transformer might be what you looking for, as I use it for mid/high Z interfacing unbalanced and balanced equipment in stadium and theater installs. The transformers you are looking at is the lower Z transformers used in vintage line level conventions that are obsolete.
https://www.jensen-transformers.com/product/din-2li/
  • DIN-2LI.pdf
