WARNING: Tube/Valve amplifiers use potentially LETHAL HIGH VOLTAGES.
Doubling the tubes will lower the source impedance (not that it will matter much) but the gain and swing are unlikely to change. If you're using the tubes to drive a phase splitter, the source impedance advantage will be practically nonexistent.
