questions on grill and removable back
well there are 2 simple ways to add a grill
1. velcro
2. there are shops that will sell those little black plastic things that you need for a grill.
if you use (2) then you have to build a frame (i use the stuff they sell as mouldings - to add a decorative touch to furniture) and using 4 45 deg. cuts build a frame. make 4 holes at each corner and attach the plastic bits. the box has to be modified to accept the plastic bits.
the back can be made so it can be screwed on and off. if you have already veneered the box you are in trouble.
