Questions about a LCD and issues
I might eventually bid on a cheap LCD, it depends on hopefully any answers i gets here 😉
The model is a Hansol 17" H711
http://www.aurora.se/hansol/hansol-711.htm
I've search for info about stripping issues and so on, but haven't found any. Your thoughts?
The bidder says the monitor dosen't ligthen up when he starts it. But you obviously can see a weak picture when windows is running.
The bidder says that the signal seems to allrigt, even if the lights dosen't work. The powerbutton has a stable light, and not changing from on/off which would be the case if it didn't had any contact with signals
Should i go for it? It's pretty cheap as a starting bid now
Thanks in advance...
