Question
A word of caution:
From what I know of T-amps (which isn't much), they cannot be connected to a sub with speaker wire inputs unless an special adapter is used. With the T-amps I have, both the black & red terminals are 'hot'; the sub assumes common ground for the speaker wire inputs & just ties the neutral lines together. I have been told that if you tie the two 'neutral' lines from a T-amp together, the amp will release the magic smoke.
I never tried/tested this, as I don't want to lose an amp.
As always: check with a knowledgeable person before proceeding--like going over to the forum where folks are building T-amps and have experience.
Cheers, Jim
