question
Normally, if you log in you won't be logged out unless you close the browser window.
If you do get logged out for this or any other reason just log in again.
If you have not closed the browser window then it may be you are getting logged out because of some technical fault. This may be irritating but it is not a serious fault as long as you can log in again.
w
