ugh, it must be late or something (i actually did outdoors stuff today, ick), but my mind isnt working, and i dont want to mess this up.
im trying to hook up my transformers i just got so i can finally power up my alephs, but i just cant seem to figure out what all 8 wires do.
they are avel lindbergs and i am using bridge rectifiers (35A/600V). here is the spec sheet from the transfomers:
http://www.partsexpress.com/pdf/avelspecs.pdf
the hookup is at the bottom, but i cant seem to understand it.
my blu, gry, vio, brn, blk, red, ora, yel wires are 0 , 115v, 115v, 0, 0, 18v, 18v, 0, respectively...
do i use two bridges per channel? i have the cap bank all ready to go. can someone helo so i could possibly power up a channel tonight?
Center tap
Input: for 110 volt
Blue and Violet neutral
Brown and Gray line
Output:
Red AC to rectifier
Orange AC to rectifier
Yellow and Black to ground
or
Output
Black AC to rectifier
Yellow AC to rectifier
Red and Orange to ground
This will give you +/- (1.4 X AC of secondaries) unloaded.
Input: for 110 volt
Brown and Gray line
Output:
Red AC to rectifier
or
Output
