question regarding hypex ucd wiring
i found this pdf explaining the wiring: http://www.hypex.nl/docs/wiring.pdf.
I do not understand why the chassis (figure for balanced input) is connected to the signal ground. One benefit of balanced connection is that you can keep the stuff that the shield on the cable has caught out of the signal ground. The figure for unbalanced input mentions ground loops and suggests not connecting safety earth to the chassis, yet for balanced input the chassis is connected to signal ground as well 😕
I thought i just leave the XLR-shield at the chassis and connect hot/cold to the amp, will that work?
Kind regards!
