as an example: mouser.com/datasheet/2/389/stps30l45c-1851672.pdf
can I treat the rectifier as 30a (2x 15A) if using both anode terminals?
thanks
thanks
Yes, you can parallel them as a single 30 amp diode. Keep the path lengths equal, especially for higher frequency operation.
Its not a transistor, there's no secondary breakdown to worry about... In fact the power dissipation decreases with rising temperature for fixed-current situations, so they will share fairly (I suspect its a single die anyway).
