I am building an entire home theater set this christmas, I have made speakers before but only 3way stereo speakers, so this is the first time I am making a bunch of speakers to match. I have a question on sensitivity. Would I want to match all towers/center/rear surrounds when building the L-pads, or should I just make them as sensitive as possible and adjust them through the reciever? (Like, the SPL's will be: Center - 85db, L/R - 93db, Surrounds 94db, subs - 94db) I think it would be a waste to build such L-pads for all of those speakers just to equalize them to the center channel's sensitivity, I think I am going to leave them this way, just wanted your imput. Thanks a lot!!
i can only assume that AV recievers will let you adjust levels.
if you are aphrehensive, look at the Audax HT kit on Madisound.com. you can do worse.
hope this helps.
hope this helps.
