Hi all, this is my first post.
I'm new to this forum but have been messing around with speakers since a couple years now.
I have some questions :
- I would like to build a speaker system for a home thearter, that would be also very good to listen music. I have an idea consisting of one or two subs (NHT1259), and all speakers would be an MTM with 2 Vifa P13. My problem is the tweeter, which do you think would be better between the Vifa XT25 and a BG NEO3PDRFP ? I'm open to anything else.
I think the P13 will be ported in a 10L enclosure tuned around 75Hz (thin column baffle). My other concern is the notch created by the distance between the two vifas.... with the dimensions of the drivers, the minimal distance between centers would be 24cm, that would be a notch around 1400Hz right ? i wanted to drive the P13 up to 2.5-3KHz... is there a way i can avoid that thing ?
I would like to Bi-Amp these columns with the little S5electronics tube kit and an active XO (so no passive XO at all). What do you think of that project ?
-Another point :
Right now I have 2 JMLabs Symbol II (mains) and 3 Boston Acoustics CR-8 (center and surrounds), wich are not really sound matched
Does anybody have the references of the drivers used in these speakers ?
Well, i think that is it for now..... sorry for all the questions...
Thanks in advance
Pierre.
-Another point :
Thanks in advance
Pierre.
