I'm now thinking about replacing my DAC analog out put NE5532 with an AD8620. Can I just simply replace it righ away, as the AD8620 pin assignments are pretty much the same as the NE5532 ones (although the AD8620 is Surface Mount Device).
By the way, all the NE5532 coupling caps are Wima (not yet backtrack the circuit how they are used).
Is there anything I should be aware of...??
