To set the tone for the rest of this message I know absolutely nothing about amp internals or electronics for that matter. So onto the newb question, which may not be a problem at all:
I just picked up an old Planet Audio Vector D, gave it a short low volume test and it worked. I'm concerned though. I opened up the amp to check it out and one of the torroid looking things (kinda like this: http://www.classaxe.com/dx/images/k9ay_torroid.jpg ) is touching the metal piece inside the amp where the fuses connect. There are a few loops of wire on the torroid that aren't tight and it stretches out to touch the the middle fuse mount on the amp chassis.
Should this torroid be toucing that fuse mount, is it possible thats how it is designed? As I said the amp still works but I didn't push it hard yet.
sorry for the bad cellphone pics
closeup of parts in question:
entire board with the parts in question outlined in red:
thanks
-bud
thanks
-bud
it looks like the input filter for the B+. it wouldn't cause much trouble since the wire is insulated with varnish but vibration could rub it off.
if you're concerned about it, you could simply bend it out of the way.
Well, turnoff pop would not be caused by this.
pop-noises can be caused by the amplifier design itself , a broken part inside the amplifer (e.g. broken transistor) or by your headunit. That means your car stereo produces a spike when it is turned off. Because most amplifiers dont shut off immideately , this spike would still be amplified.
You could check the following: disconnect the RCA cables from your amplifier. Turn the amp on, and off again. If you still hear the pop noise , the amplifier itself causes it. If there is no pop-moise anymore it´s your car stereo.
duece212 said:only problem with the amp is that it has a turnoff pop, otherwise everything else is ok.
Had a Planet Audio Titan TT850D. Same turn off pop noise (no turn on noise at all).
Verified every possible cause (I even switched amps) and ran all test the tech support sugestes with no luck.. had to live with it.
What's ther amp model?? I want to use the picture in the amp guts page, is that ok?
BTW Planet Audio tech support is AMAZING.. and I mean it.
amp
the thump sound you could be hearing could be from cheap rca wires if you know some one that has a system hook your amp up in there car to check most of the time that sound is feed back or a bad ground but i dont know every thing
- General Interest
- Car Audio
- question on amp internals
