I'm looking for an op-amp to replace a TL074 in an active filter application. Any suggestions for quad packages as a drop-in replacement for an existing product?
I haven't really decided on target performance yet, but lower noise JFET types are the immediate goal.
I've had a quick scan through the parametric searches, but would love any other advice from those who've tried alternatives.
A.
A.
Search the forum for "Brown Dog" and you will find various adapters. I would go for an adapter that would adapt 4 single SMT units to a quad if available and add local decoupling in the process.
If such adapter is not available I would make one myself. It is not that hard.
Petter
Petter
Quad adapters
AFAIK Brown Dog is not making any singles to quad adapters: only duals.
Which is a pity, because the ART DI/O DAC, which is one of the most modded units right off the shop, uses quads. And one of the better mods is using AD825s.
People are using LT1362/1365 instead, FET biased to class A. But they are expensive quads.
Carlos
Carlos
- Question for op-amp guru's
