Question about SE transformer issue
The culprit could also difference in core properties. If the LCR picks up the main L with parasitic Cp+Cs resonance, main L could vary if for some (BAD) reason the core isn't exactly the same.
P.S. Looks like you, at least partially solved the issue. Quite a huge difference in capacitance, IMHO.
Highly possible, yes. Paper varies in density, hardness, all can result in difference of dielectric constant. You should always test your dielectrics before applying them to an audio transformer. pH water test, capacitance test between two plates and dielectric breakdown test, if to be used between high voltage potentials.
