Question about relays
Can you confirm this to be true?
This is a comparison to the OMRON G2R relay I mentioned.
For the pinout you need its only rated 10A, but it's well categorised.
From the datasheet it exceeds your old relay and should work fine.
Attached is a comparison on DC breaking current.
I'm currently using there 16A version (different pinout) for almost everything.
