Question about plate load resistor with slight change in value
That is about 2% difference, Most tube amps were built with 10 or 20% resistors and occasionally 5%. So it is well within the design specification. Not to mention that today 1% resistors are usually cheaper than 5% resistors. Tubes are much more forgiving to bias levels and occasional overload than transistors, tubes distort more, transistors explode.
I have seen tenth's of old radios working with resistors of the very early types: a carbon bar with a color body, one central color dot and one in the end. Sometimes, the guy who assembled the radio, hasn't the proper value, then he "trimmed" it filing the body of the carbon bar. The tolerance, then, may be ±100% :-D, and most of them had maintained their value reasonably well during several decades. I believe I still have some of this old kind of resistors.
